I have avi video that has CM and unwanted scene, so I cut off CM and unwanted scene in adobe premiere pro 2, then I exported to movie from premiere pro, result is the video size is way TOO BIG!!! original avi video size was 359MB, but after export, it is 10 GB!!!
WHY?? I want to keep original video size. so What should I export??
Premiere simply wants to conform your video to the current Project Settings...
So if your original .AVI was compressed, Premiere will try to "recompress" to the project settings...
If you're using the standard DV settings, then expect 13gig/hour..
You should try and create a project setting to match the original footage.. -
ok I understand now.
So How should I export to keep original size??
Should use microsoft dv AVI or microsoft AVI using DIVX 6???
I am newbie, so can you explain more detail??
Thank you!! -
Yes, go to the Settings dialogue box...
Go to "Custom settings", and fill in all the information, including framesize, compressor, etc....
Many people have had trouble in the past using DivX codec..
Primarily, Premiere is a DV editor...Since each frame is a keyframe, it edits great..
Within DivX keyframes can be spread out quite far.. -
Where can I find custom setting??
There is setting tab when I click on EXPORT- MOVIE...
I don't know how to set frame, birate, etc.....
Is there good tutorial for setting codec?? -
Google is your friend...
I'd start here, and see you in six weeks.....
From Vegas to Final Cut Pro - How to export without (much) quality loss
By BovineofWar in forum MacReplies: 18Last Post: 28th Apr 2010, 21:04 -
Final Cut Pro Slow Export
By gooberguy in forum EditingReplies: 1Last Post: 5th Apr 2010, 16:23 -
very slow export from premiere pro 2
By yunakokimama in forum Video ConversionReplies: 5Last Post: 27th Mar 2008, 13:10 -
Using Canopus ADVC110 to Export to VHS from Final Cut Pro
By richisgame in forum MacReplies: 4Last Post: 14th Sep 2007, 19:18 -
Help with scene color matching in Premiere Pro CS 2/3
By Sparc in forum EditingReplies: 3Last Post: 26th Jul 2007, 08:27
