I'm covertign several VOB files (20min each) to "ipod mpeg4-480w" at 1000kbps, 480x360, 112kbps AAC audio.
It all works very well using ffmpegx 0.0.9x on my 1,5GHZ powerbook 12".
But sometimes it just stops the conversion in the middle of the progress...at random percentages. It doesn't prompt an error, the number simply stays the same. As well as the filesize.
But it happens more often the more files I put in the queue... Sometimes the first progress freezes, sometimes the third....There seems to be no system at all behind all this.
Please, anyone tell me this is a commom Problem with a simple solution![]()
Thanks in advance!!
This seems to be a very common problem -- Progress seems to be a bit of a vampire process, and if you try to take away some of its resources (say, even by just clicking on another window), it'll hang your 'book for some time. If it takes too long, Progress times out, and you're SOL.
I've not found any workaround, other than not to touch the mac at all until it's done with its conversion job. "Touch" here includes virtual touching -- disable any networking apps (turn off Airport, disable automatic time server synchronization, etc). Just let ffmpegX and Progress have the whole machine to themselves. If I do that, I tend to have few problems.
And as you've noticed, the deeper the queue, the more likely the occurrence of the problem. Keep queues short.
man, I wish you would have said something like "oh, no problem with that. just quit app xy while encoding and it'll work fine." or "install this patch and you're done."
well..thanks anyway. seems I just have to give ffmpegX what it wants....even if that is EVERYTHING
I wish it were that easy. I am hoping that someone else will chime in with "no, you dummy; just type these magic commands in a terminal window, and all will be better." But like you, I just give ffmpegX whatever it wants, and hope for the best.
--Cheers,
Tom
i guess "nicing" the process will make it even more unstable. this hast to have something to do with ffmpegx itself, while "nice" is a system command. But worth a shot!
Create a new user account. Log in and see if anything changes. If so, you know what to do. If not, check to see what extensions and startup/login items you have running. Last resort: Archive & Install a new OSX.
I must stress that I've never experienced anything like what you are reporting so I have to believe it's something in your system that is causing the issue and not ffmpegX.
MeGui: error in encoding: "x264.exe:unrecognized option --progress"
By Julllie in forum Video ConversionReplies: 4Last Post: 30th Apr 2011, 06:21 -
"Where is Progress.app?"
By lemonade in forum ffmpegX general discussionReplies: 3Last Post: 17th Nov 2010, 10:44 -
"where is progress .app" in panther.
By pantherxxx in forum ffmpegX general discussionReplies: 1Last Post: 9th Feb 2010, 19:32 -
"Where's progress app?" error when trying to decode VCD
By rossi in forum ffmpegX general discussionReplies: 8Last Post: 19th Aug 2008, 01:48 -
ffmpegX jumps to "finished" crashes computer, lost progress.app
By jegler in forum ffmpegX general discussionReplies: 16Last Post: 2nd Jun 2008, 20:53
