I'm trying to capture video from my camcorder using Windows Movie Maker, which creates WMV file. When I convert this to DVD format it's not very clear.
1. What format gives the best quality for playback in a DVD player?
2. What software should I use to capture video from camcorder?
3. Am I losing quality by capturing to WMV format?
Results 1 to 10 of 10
With MM2, it is also important that you export in DV-AVI format (found under "other formats" under "save to my computer"). Then import the DV-AVI file into your DVD authoring program.
You can save much time by using a DVD authoring program like ULead MovieFactory 5 that will import directly from the camcorder. If you are looking for more editing features, consider one of these.
Adobe Premiere Elements
Sony Vegas Movie Studio
ULead Video Studio -
Yeah, I'm using the firewire port for capturing.
I'll try you suggestions & see if that helps out.
Also, I noticed when I convert from WMV format to DVD using AVI2DVD it loses the sound after approximately 10-15 seconds....any ideas why?
Thanks for your help! -
WMV is pretty much a final product sort of format. Not much software aside from media players deal well with it.
With MM2, it is also important that you export in DV-AVI format (found under "other formats" under "save to my computer")."
MM2 doesn't give me an option to change to other format under save to my computer -
Microsoft does everything they can to lock you into Windows. Hence the lack of formats to convert to.Originally Posted by bmossman
1. Under "Finish Movie", "Save to My Computer"Originally Posted by bmossman
2. Name File, next
3. "Show More Choices"
4. "Other Settings"
5. down arrow, DV-AVI
As Douglas Adams wrote in the Hitchhikers Guide to the Galaxy ...
Something like ... "It was in plain sight under the stairs in the lower basement". -
Oh, I thought he was asking if there was something other than DV AVI and WMV. Like MPEG 2.
Thanks for the iall the input....it worked alot better without the loss of quality!
HD Video Capture questions
By lost123 in forum Capturing and VCRReplies: 8Last Post: 29th Jun 2011, 22:02 -
Multiple questions about HD video capture (broadcast, Happauge, Tivo)
By jpt85 in forum DVB / IPTVReplies: 36Last Post: 13th Apr 2011, 20:02 -
Capture Card Questions
By Veldimare in forum Capturing and VCRReplies: 8Last Post: 18th May 2010, 15:14 -
Questions for Improving Sony DCR-TRV22 Video Capture Support
By fredberry in forum Capturing and VCRReplies: 3Last Post: 2nd Nov 2008, 15:59 -
Capture settings or other issue? (Interlaced video, and a few questions...)
By DonnieC in forum Capturing and VCRReplies: 5Last Post: 30th Sep 2008, 13:03
