Hi,
I have a major problem with ffmpegX video converting. All converted files "stutters" the playback. I'm trying to make a .flv files but this problem is with all codecs. It also dont matter what files i try to convert the result is allways a jerky video.
I tried with Quad G5 and Macbook Pro but same problem with both.
Here's the info of two different files:
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
Wed Nov 8 15:23:47 EET 2006
, gcc: 4.0.1 (Apple Computer, Inc. build 5250)
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/xx/MVI_0070.MOV':
Duration: 00:00:30.0, start: 0.000000, bitrate: 3030 kb/s
Stream #0.0(eng): Audio: pcm_s8, 11024 Hz, mono, 88 kb/s
Stream #0.1(eng), 15.00 fps(r): Video: h264, yuv420p, 640x480
Output #0, flv, to '/Users/xx/MVI_0070.MOV.ff.flv':
Stream #0.0, 12.00 fps(c): Video: flv, yuv420p, 320x240, q=2-9, 200 kb/s
Stream #0.1: Audio: mp3, 22050 Hz, stereo, 56 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Stream #0.0 -> #0.1 [sync #0.1]
video:420kB audio:206kB global headers:0kB muxing overhead 62.398968%
bench: utime=6.621s
Encoding completed on Wed Nov 8 15:23:54 EET 2006
Wed Nov 8 14:32:34 EET 2006
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/xx/LAPTOP.mov.ff.flv':
Duration: 00:03:48.0, start: 0.000000, bitrate: 1061 kb/s
Stream #0.0(eng): Audio: aac, 44100 Hz, stereo
Stream #0.1(eng), 25.00 fps(r): Video: h264, yuv420p, 320x240
Output #0, flv, to '/Volumes/xx/LAPTOP.mov.ff.flv':
Stream #0.0, 25.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, 400 kb/s
Stream #0.1: Audio: mp3, 44100 Hz, stereo, 96 kb/s
Stream mapping:
bench: utime=23.714s
video:2750kB audio:2672kB global headers:0kB muxing overhead 112.832253%
Encoding completed on Wed Nov 8 14:33:00 EET 2006
Here's the .flv file:
http://www.yousendit.com/transfer.php?action=download&ufid=EA46174E550C37E0
Any suggestions?
Maxx
Results 1 to 9 of 9
This one should be stuttering. (a) Half the framerate of what we're used to (on tv), to begin with; and (b) framerate change during conversion, thus frames are dropped.Originally Posted by supernauris
This one should be quite good; just as smooth as the source file.Originally Posted by supernauris
But it's not and that's the problem. I know that the original is 25fps so i try to output it to 25fps but it's still jerky. Actually it looks same with any framerate. I'm probably missing something small in the settings since it don't matter what the source file is or what the output codec is.Originally Posted by Case
Here's a new test file: http://www.yousendit.com/transfer.php?action=download&ufid=52CA21ED036F7ED4
Thu Nov 9 10:01:05 EET 2006
Seems that stream 1 comes from film source: 25000.00 (25000/1) -> 25.00 (25/1)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Volumes/xx/Under_Doves_wing320x240_2.mov':
Duration: 00:01:18.8, start: 0.000000, bitrate: 9625 kb/s
Stream #0.0(eng): Audio: adpcm_ima_qt, 32000 Hz, stereo
Stream #0.1(eng), 25.00 fps(r): Video: qtrle, rgb24, 320x240
Output #0, flv, to '/Volumes/xx/Under_Doves_wing320x240_2.mov.ff.flv':
Stream #0.0, 25.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, pass 1, 400 kb/s
Stream mapping:
bench: utime=8.648s
video:1484kB audio:870kB global headers:0kB muxing overhead 78.435320%
Stream #0.0, 25.00 fps(c): Video: flv, yuv420p, 320x240, q=2-15, pass 2, 400 kb/s
Stream mapping:
bench: utime=8.831s
video:1539kB audio:870kB global headers:0kB muxing overhead 101.742021%
Encoding completed on Thu Nov 9 10:01:28 EET 2006
a) This MOV is H.264/AAC, unlike what your log shows???
b) Initially, I got the same results on converting to FLV.
c) When replacing the audio with uncompressed PCM audio in QuickTime Pro (*), the converted file did get a smooth framerate. I wish I knew why...
(*) Export Sound to AIFF. Delete sound track. Select all in AIFF file, copy, select all in MOV file, add clipboard to movie. Save as self-contained movie. Convert with ffmpegX to FLV @ 25 fps, best bitrate.
No, it should have worked the first time. But it can sometimes help with problematic files. It's just one of the things I try when nothing else works: if the source file is 'too difficult' for ffmpegX, then I try to feed it an 'easier' version of the same information.Originally Posted by supernauris
Problems converting MP4
By Nikar in forum Video ConversionReplies: 4Last Post: 17th Jul 2010, 12:39 -
Problems converting FLV
By am_dew in forum Video ConversionReplies: 8Last Post: 15th Jul 2010, 00:02 -
problems converting to apple tv
By noizemaker in forum DVD RippingReplies: 0Last Post: 20th Jun 2010, 09:42 -
Different converting problems
By saiden22 in forum Video ConversionReplies: 3Last Post: 2nd Jan 2008, 13:29 -
Problems converting from MP4
By bboypkj in forum Video ConversionReplies: 2Last Post: 27th Nov 2007, 21:57
