How do you put a dvd, that's 4-hours onto a '2-hour disk
Using DVDShrink& Etc
There is no such thing as a two hour disc. Just load your DVD files into Shrink and let it work out how much compression it needs. You are asking a lot though, with three hours about the threshold for full resolution DVD on a single layer disc. You may find Shrink cannot do it in the first go, and you have to load the results from Shrink to shrink it again.
Personally, I wouldn't use Shrink for four hours of video. I would use DVD Rebuilder and encode it at half-D1 resolution.Read my blog here.
dvd shrink- how much compression...
By Bletch in forum Newbie / General discussionsReplies: 15Last Post: 20th Jan 2012, 17:24 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 07:45 -
DVD Shrink compression method question
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 14th Jan 2009, 12:42 -
compression and DVD Shrink
By snafubaby in forum Authoring (DVD)Replies: 2Last Post: 13th Dec 2007, 01:15 -
DVD Compression/Shrink Software Recommendation?
By Noy2014 in forum DVD RippingReplies: 7Last Post: 13th Jun 2007, 06:12
