Hi,
I'm a little confused- I open a wav file in Adobe Audition 1.5, go to time stretch and apply speed correction using the resampling mode. The file comes out to be 6 minutes, and 59.23 second, the desired result.
I then put this file into Vegas 6.0. Now all of a sudden Vegas reports the file to be 7 minutes and 01.10 seconds.
So what went wrong there? Why would two different programs produce conflicting results? I need the sync down to tenths and hundredths of a second or else it will throw the whole project off. I have never encountered this problem before and would like to know what is causing it.
Please, any insight would be appreciated.
in project properties - select the highest sample rate conversion settings
if you just stretch it out on the time line - it also will work fine (still set properties)"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thanks again. I did as you said and that seemed to eliminate some of that nasty "echo" or "repeating". I always left click, go to properties, and go to the "time stretch/pitch stretch" to do a speed correction.
But, in regard to the time line, if I physically move the left and right borders around, it doesn't change the speed. It only shortens or doubles the audio file. So I think I am doing something wrong.
I'm trying to get a feel for Vegas by trying out other methods, that's why I ask about this stuff. -
hold down the control key and the pointer will change - then grab the end and drag ,, see also the help file and manual
Deinterlacer that produces non-flickery 1080p?
By Asterra in forum Video ConversionReplies: 3Last Post: 15th Apr 2011, 21:03 -
MKVMerge produces smaller file
By Bung in forum Newbie / General discussionsReplies: 1Last Post: 20th Apr 2010, 03:23 -
Strange DVD SPEED test results
By tac7 in forum DVD RippingReplies: 5Last Post: 2nd Apr 2009, 22:24 -
Speed Test Results
By HmNtr in forum Off topicReplies: 0Last Post: 28th Dec 2008, 02:58 -
Speed Correction (Time Stretch) In Audition.... Few Q's
By Liquid Drum Theater in forum AudioReplies: 11Last Post: 25th Aug 2007, 12:41
