Hi all.
I'm working with web, and when using video i always use lower frame rates..as 15 or 21..
Normally i convert the videos to FLV with sorenson squeeze. I Converted a movie from 24 fps to 21 .. and i can actaully see the video skipping a frame here and then....
I guess thats what sorenson squeeze does..skip a frame every x frame.
My question is..does the "real" video software packages do any better?..or do they also use same "skip" frame technique.. or do they "blend" transitions betwen missing/duplicate frames.
what should i exspect?
I wouldn't expect they would blend...in order to blend, they would need to create a frame, which would be pointless when you are dropping frames.
Google is your Friend
How Create ACHD side by side compatible with Panasonic 3D Cam and HDTV?
By castana in forum Video ConversionReplies: 7Last Post: 25th Jul 2011, 15:47 -
Issues Converting from 25 fps to 29.97 fps
By Klagar in forum Video ConversionReplies: 7Last Post: 13th Jul 2011, 11:30 -
Is the panasonic dmres46v a seudo svhs side-by-side player/recorder?
By yoda313 in forum RestorationReplies: 8Last Post: 17th May 2010, 08:09 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 18:26 -
Converting 23.976 fps to 29.9 fps
By zanos in forum Video ConversionReplies: 4Last Post: 13th Apr 2008, 09:03
