Hello, I just bought a Sony 8mm CCDTR83 (1995). The video works great either on a TV set or after capturing on my computer. There is no audio coming through either from my old tapes or on a new one with new recordings. I have tried a different audio/video cable set and same proble.
Any ideas![]()
Thks, Davco
Do you have the manual for it? Maybe a switch or setting on the camera?
Can you hear the sound thru the camcorder speaker, when you play back ?
Checked the manual, checked the settings in menu, can either have Stereo, 1 or 2. Even with the cam corder plugged into the TV and in record mode, the video is working but no audio.
Thks, Davco -
If you don't have sound thru the camcorder speaker, then you have a broken camcorder.
yep...even camera stores pawn off units that have no sound as fully functional because sound is rarely checked
trust me on this one
Best Sony Digital8 Camera to convert 8mm/Hi8 to PC?
By Optical in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 30Last Post: 7th Oct 2017, 12:34 -
8mm Pal to NTSC
By GR8LAKER in forum Newbie / General discussionsReplies: 3Last Post: 16th Mar 2011, 08:48 -
8mm Videotape Playback issues on Sony VTR
By nazopo in forum MediaReplies: 1Last Post: 22nd Dec 2010, 20:47 -
8mm tapes PAL with NTSC camcorder????
By igorv in forum Capturing and VCRReplies: 5Last Post: 11th Oct 2010, 14:17 -
Failing elderly Sony 8mm camcorders
By pgoelz in forum Capturing and VCRReplies: 5Last Post: 29th Mar 2010, 20:44
