So, just got my Vegas 7 version and found that something is missing or am I just lost?
In vegas 6, when you add an effect to a clip or so, you can edit the effect with keyframes in the bottom of Video Event FX.
For example:
I insert a video clip and choose the effect Light Rays. I can now move the Light Ray effect around on the screen. And now if I whant the Light Ray to move from left to right during the clip plays I just use the keyframes in the bottom of my window. Easy
But now when I got Vegas 7 there is NO keyframes or anything down there. Where are they?
If you take Pan/Crop for example the 'Timeline' where you can insert Keyframes are there. But where did it go when it comes to effects?
I just installed the 7.0b trial version. Nothing has changed. The keyframe menu can still be seen under the Track Motion and the Pan/Crop section but for Video FX, nothing is there
http://img295.imageshack.us/img295/6745/keyframetr0.jpg
Total keyframes?
By anonymous_whatever in forum Newbie / General discussionsReplies: 41Last Post: 12th Feb 2012, 10:33 -
Listing keyframes
By Misterer in forum Newbie / General discussionsReplies: 0Last Post: 14th Aug 2010, 10:36 -
Are variable keyframes possible?
By x2x3x2 in forum Video ConversionReplies: 15Last Post: 7th Aug 2010, 07:40 -
Increase the density of keyframes
By Stasik0 in forum EditingReplies: 11Last Post: 6th Jul 2010, 07:15 -
Are I-Frames the same as Keyframes?
By leopard in forum ffmpegX general discussionReplies: 4Last Post: 1st Aug 2009, 07:23
