Hi guys,
I am kind of new to this, so please bare with me. There are some rmvb files I want to convert into mpeg2 so that I can use my MovieFactory3SE to create DVD from them. I tried Super converter, some of them worked but some just refuse to convert and showed error.
In Super, I tried using mencoder and the conversion would just stop in the middle, showing mencoder.exe crashed error. If I re-try, it happens in exactly the same place everytime as I review the output file.
I then tried ffmpeg (with and without 'Use DirectShow'), which just stopped in the beginning and created a 0 byte file with error. The strange thing is if I 'disable Audio' it will convert alright.
Here's the information of the file in Super.
General #0
CompleteName : C:\Files\Alex\Japan Cartoon\Fixed29.rmvb
FileSize/String : 222 MiB
Format/String : Real Media Format
OveralBitRate/String : 702 Kbps
PlayTime/String : 580h 33mn
Copyright : (C) 2006
Video #0
Codec/String : RealVideo 4
Codec/Info : RealVideo 9
BitRate/String : 574 Kbps
Width : 512
Height : 384
AspectRatio/String : 4/3
FrameRate/String : 24 fps
Resolution : 12
Bits/(Pixel*Frame) : 0.122
Delay : 0
PlayTime/String : 43mn 50s
Audio #0
Codec/String : AAC
Codec/Info : Real Audio 10 AAC (RAAC)
BitRate/String : 128 Kbps
Channel(s)/String : 2 channels
SamplingRate/String : 44 KHz
Delay : 0
Video0_Delay : 0
PlayTime/String : 43mn 51s
Can some one give me some help, please?
Cheers,
Alex
I recently had to encode to MPEG2 such a file (RM with AAC audio) using Avisynth + CCE (the most 'clean' method). The problem was that AAC audio was not found by Avisynth and I had to decode it to wav separately using EO Video (FFDShow gave one of its audio decoders, not DShow type as I guess). I used original sample rate and linear mode in EO Video, then processed in SoundForge.
Opened the video stream in AviSynth as Direct Show Source (RealAlternative installed), added cropping (to remove letterboxing), resizing and sent it to CCE. Both streams were in synch after encoding. You'll find the link to RM/AviSynth manual in the post above.
Problem with converting MOV to MPEG2
By encAmateur in forum Video ConversionReplies: 5Last Post: 18th May 2011, 03:56 -
Converting RMVB to MP4 problem...
By xkiller213 in forum ffmpegX general discussionReplies: 2Last Post: 28th Aug 2010, 12:19 -
HD RMVB Converting Problem
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 1st Feb 2010, 16:42 -
Problem converting RMVB to MP4
By Calilin22 in forum ffmpegX general discussionReplies: 20Last Post: 24th May 2009, 07:07 -
problem with converting rmvb
By fustyler in forum ffmpegX general discussionReplies: 4Last Post: 29th Aug 2007, 21:11
