I need to fix audio in an avi file with AC3 track. I was trying to do that in VirtualDub, but I don't see AC3 compression option and because of that I get an error. Is there a software that can fix audio delay?
moved to another forum, nobody likes me here...
Install AC3 ACM Decompressor or AC3 filter if you want virtualdubmod to play the AC3 audio. To add a delay (in either direction) go Streams->Stream List, right-click and choose Interleaving. Bottom half of the screen allows you to move the audio. Save out under Direct Stream Copy to preserve video and audio.
Read my blog here.
I have AC3 filter installed, but I made a mistake using full processing mode. Do you know how to the best determine what number to put for the delay fix?
moved to another forum, nobody likes me here... -
Aside from guessing ? Media Player Classic has an audio skew adjustment so you can make the change, listen, change etc until you get it right, then use this number in vdub. You could also have a look at syncview
Read my blog here.
How to fix delay on subtitles?
By nemi in forum SubtitleReplies: 8Last Post: 1st Mar 2012, 12:05 -
Join two avis... the 2nd has 3ms audio delay? how fix that?
By CactusMan in forum Newbie / General discussionsReplies: 4Last Post: 21st Mar 2010, 02:59 -
Joining MPEG2 files with different AC3 audio delay on each file
By Killer3737 in forum EditingReplies: 6Last Post: 28th Oct 2008, 00:32 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 19:00 -
How to fix delay???
By X_Splinter in forum Authoring (DVD)Replies: 5Last Post: 8th Oct 2007, 12:03
