    Jul 2004
    When I connect my MacBook Pro to my HDTV (Sharp Aquos 37") via DVI cable, the signal looks great.
    However, every 30 seconds or so, the signal gets a strange irregularity. It's hard to explain, but the displayed image seems to "split" -- with the bottom portion of the screen slightly off alignment. This "split" moves slowly upward on the screen until it gets about half way to the top, then disappears. It's pretty frustrating to see.
    Anyone know what could be the root cause? Is it my DVI cable? My laptop? My TV? Thanks in advance...
    Memphis, TN
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    sounds like a timing issue between the laptop and tv... powerstrip might be able to fix it
