I have a matroska file with h264 encoded video and 6ch he-AAC audio.
I have media player classic 6.4.9.0....with core avc loaded
and ac3 filter 1.11 also loaded.
I have a HTPC with SPDIF connection to a DD/DTS 5.1 surround amp.
The picture is superb!!....but!
How do I get it to play the 6ch ie...5.1 sound... out via my surround amp
to the speakers???
I have played DVDs and Avis with DD5.1 no problems!
I have been fiddling ...for half a day...with the settings in AC3 filter to try
and get output ...
but no luck!
Am I trying to do the impossible?? ie decode 6ch AAC to feed through
to my surround amp??
This problem is so frustrating
The only way you can do what you are trying to do is to direct the output via separate analogue outputs for each channel, connect these into the multi-channel analogue inputs on your amp, and from there to your speakers.
The spdif won't work because it only sends digital audio data, and your amp cannot decode AAC.
Your only other choice is to convert the AAC to 5.1 AC3, then play it back through your existing kit.Read my blog here.
Thanks ..gunslinger
I assume most people playing these types of matroska files(with 6ch aac)
must have games(ie xboxs) setups with analogue 5 speaker setup connected.
I also assume converting this 6ch aac audio to DD 6ch is complicated?? -
Several ways to do it actually.
1) Dolby live sound card hardware encodes to AC3.
2) DTS connect sound card hardware encodes to DTS.
3) ffdshow software encodes to AC3 and uses SPDIF.
4) I think AC3Filter can also do realtime software transcoding.
A Dolby live/DTS connect sound card is obviously the easiest.
http://www.auzentech.com/site/products/x-plosion.php -
So there maybe software solutions to getting the
....6channel AAC audio...
to be converted for output to an 5.1 surround sound receiver
and on to associated speakers?? (ie FFDshow or possibly AC3 filter)
Or if you get an Auzentech Digital X-Plosion 7.1
DTS Connect Sound Card...then no matter what the source
you can output DD5.1 or DTS5.1?
I have been playing with AC3 filter ...to try and get this but without
much success.....mind you ...its really been without much understanding
of how to change the ac3 filter settings....just turn this off or try this on!
It would be nice if someone could do a basic guide of the AC3 filter...
someone who understands how this filter works.
looks like I may have to look at one of these Auzentech cards...
MP4/AAC -> XVid/AC3 6ch
By brugi in forum Newbie / General discussionsReplies: 16Last Post: 20th Aug 2014, 22:43 -
MP4+AAC 6ch streaming using PS3 Media Server
By faissalfilho in forum Video Streaming DownloadingReplies: 1Last Post: 6th Jun 2011, 06:12 -
Converting MKV with 6ch AAC to AVI/MP4?
By Startropic1 in forum Video ConversionReplies: 1Last Post: 7th Nov 2010, 10:26 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 17:58 -
MKV to MP4 for PS3 with dual-audio (2ch AAC + 6ch AC3)
By sexyclient in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Dec 2008, 23:01
