I have a movie that's in avi format and has subtitles. I normally use ConvertXtoDVD to convert my avi's to dvd. But it won't let me add the subtitles before I hit convert. Is there an easier way to do this?
You may have a different format of subtitle that ConvertXToDVD doesn't like. There are several formats commonly used. Since this is mainly about subtitles, I'll move you to the subtitle forum and you may get more information there. Check the 'stickies' at the top of the forum and they may help. Should be easy enough to change most subs to a different format.
What is the subtitle extension extension? -
.sfv and i tried chaning it to .srt but convertXtodvd still won't let me load em.
How did you change it ? Subtitle workshop can be good for some formats.
Do they have the same name as the movie file ?Read my blog here.
That might be the problem:
http://en.wikipedia.org/wiki/SFVSFV is an abbreviation for simple file verification, a checksum format using the CRC32 algorithm to verify the integrity of files.
According to Subtitle Workshop, it currently supports around 56 subtitle formats. I didn't know there were that many formats.
These seem to be the most common:
SubRip
SubViewer (1 & 2.0)
MicroDVD
SubStationAlpha
Sami
More info here: http://www.doom9.org/index.html?/sub.htm -
SFV is a checksum.
Open the file in notepad and see if you actually see subtitles.
Converting .mkv to .avi subtitle problems?
By oxadiba in forum SubtitleReplies: 1Last Post: 9th Apr 2011, 09:45 -
Audio/video/subtitle sync problem converting MKV to DVD (Muxman issue?)
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 7th May 2010, 11:23 -
Xvid4psp 5.0 problem converting .mkv to .avi with subtitle
By Conrad007 in forum Video ConversionReplies: 3Last Post: 13th Jan 2010, 14:15 -
Converting AVI file with separate subtitle track
By dgarmaise in forum ffmpegX general discussionReplies: 2Last Post: 7th Jun 2008, 08:08 -
Converting SRT or SUB subtitle files as a Subtitle Track for DVDs...
By soneman in forum Video ConversionReplies: 3Last Post: 22nd Feb 2008, 14:17
