flv extract produces and audio stream in mp3 format whereas virtualdub only loads wav apparently. damn!
I thought virtualdub could also load mp3's.
lame 3.96 is the one I use to register
My second question is how do I load an mp3 audio track in virtualdub 1.6.17
As far as I can see there is an option to load wav so when I try to load mp3 it throws an error.
Thanks -
Sorry, I use VD Mod most of the time. I hate to say it, I don't know how to add a MP3 audio track with VD 1.6.17. I assumed it was similar for adding audio
Easy with VD Mod, just use 'Add' in the 'Streams' window, then add just about any type of audio you want. I must be missing something with VD 1.6.17.
Virtualdubmpeg2 is closer to virtualdub than virtualdubmod. In it you can go Audio -> Browse for Audio, and you wav, mp3 and AC3 as options.
Read my blog here.
Yes but virtualdub-MPEG2 does allow for loading the file although flv extract seems to produce an mp3 that is not compatible for VDMpeg2 as it does show and error loading the file even though mp3 is listed in the dropdown window to load such fileOriginally Posted by guns1inger
FLV Extract Cropping Error
By TAS257 in forum Newbie / General discussionsReplies: 8Last Post: 26th Apr 2012, 21:55 -
Riva makes my FLV's bigger + can I use VirtualDub to create FLV's?
By OM2 in forum Newbie / General discussionsReplies: 9Last Post: 13th Jan 2010, 14:53 -
Extract audio from FLV (on Mac)
By matt276 in forum Video ConversionReplies: 2Last Post: 22nd Dec 2009, 13:26 -
FLV audio out of sync, can't work VirtualDub w/ FLV plugin
By ZantarV in forum Video ConversionReplies: 1Last Post: 4th Sep 2009, 12:51 -
FLV Extract -> TMPGEnc - how?
By akrako1 in forum Video ConversionReplies: 20Last Post: 22nd Aug 2009, 20:00
You might upgrade the MP3 codec for VD with
