I ripped the contents of a DVD using DVD Encrypter. Then, I tried to use DVD2AVI to convert the *.VOB files to *.d2v and *.wav. The articles on the net(http://www.vcdhelp.com/dvdtovcd.htm) say that after the conversion is done, I would have two files .d2v and .wav. I have got the d2v but no wav file. I am not sure if I am missing out something very simple. Any help would be greatly appreciated. Thanks.
under the audio tab on dvd2avi you can select the track. it usually track 1 and is set there by default. but sometimes it is track 2 or 3 etc.
i've only seen it be one or two for region 1 -
This mean the first track is DTS and DVD2AVI can't decode it.
Catman
5.1 wav or 6 mono wavs to 5.1 Ac3 conversion
By wturner in forum AudioReplies: 38Last Post: 24th Nov 2013, 08:26 -
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
Correct AR(aspect ratio) on dvd2avi conversion (16:9 vs 1.85:1)
By Visual-Artist27 in forum DVD RippingReplies: 10Last Post: 19th Aug 2010, 23:11 -
audio conversion problems? (wav to ac3
By just in forum Newbie / General discussionsReplies: 9Last Post: 28th Oct 2008, 18:35 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 14:08
