I installed ac3 filter and still have the problem
They work right with VLC media player.
Results 1 to 9 of 9
Give us as many specifics as possible. Ie., what did you use to encode, author, etc.
gspot
"They work right with VLC media player. "
"play fine on my standalone dvd player"
and the problem is???Corned beef is now made to a higher standard than at any time in history.
I too had the same problem, 'BirdDaddie'.
For me, it was solved by opening the AC3 settings dialog, and playing around with the 2 dropdown lists in the 'Output' section of the 'Main' tab.
I found that simply checking 'Use SPDIF' made all of my woes go away.
All files play fine (AC3/non-AC3), and I've made NO adjustments to the gain settings whatsoever.
As always, play around with the settings, and keep loading WMP each time to check on the changes (if you don't actually reload the whole program, it won't use your new decoder profile)
Hope this helps you out.
Playing old AVIs on new DVD player
By tandanus in forum Newbie / General discussionsReplies: 4Last Post: 28th Aug 2011, 19:50 -
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
No Sound When playing MKV files in wmp or media player classic
By tmiller_15 in forum Blu-ray RippingReplies: 2Last Post: 13th Jun 2009, 00:24 -
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
video encoded with divx can't seek with HW player?
By samykoka in forum Video ConversionReplies: 5Last Post: 10th Apr 2008, 16:07
