Hello,
I just bought a Pioneer DVR-531H-S standalone DVD recorder.
It says it plays "Store Bought DVDs, DVD-R, DVD-RW, and DVD-RW DL"
I have a lot of movies on DVD+R. I am guessing that I won't be able to play them on my Pioneer (I haven't been able to try it yet, because I just ordered it and it hasn't arrived yet), because they are +R and not -R.
But what about commercial DVDs??? Are they DVD+R or DVD-R, or something else all together?
Thanks!
Something else all together.Originally Posted by christopheramosJohn Miller
Okay, thanks. I hope this next question isn't a violation of VideoHelp rules. I apologize if it is.
But I've read where DVD Recorders can be hacked ??? I don't know what that really means. Can a unit be hacked to play different forms of media (say DVD+R as well as DVD-R)?
Thanks! -
The hacking usually refers to disabling region control and other 'soft' items.
Compatability between DVD-R and DVD+R is usually more of an issue for recording them in the first place. There's a table of playback compatability here: http://www.dvddemystified.com/dvdfaq.html#4.3.1
Simplest thing to do is try one of your DVD+R discs in your new unit.John Miller -
"...what about commercial DVDs??? Are they DVD+R or DVD-R..."
They are PRESSED, not dye-based as recordable are. turn the DVD's over...pressed are NOT blueish.
Your recorder should play both + and - recordables. -
My 531h plays both +R & -R and I've Played +R Dual layer in it. You will need -R discs to record on as it will not record on +R discs. I haven't tried -R Dual Layer yet. I use it via Component Out to a HDTV now and used to use it via S-Video to a SDTV. You can find a lot of info on this recorder here. Just search the messages.
Cheers -
Great!! Thanks everyone!!! It's good to know that I'll probably be able to play my DVD+R movies. It would be a real pain to go back and re-record them onto -Rs!!!!
Regards,
Chris
store bought dvd won't play in laptop or pc, can't copy
By ghola in forum DVD RippingReplies: 11Last Post: 8th Mar 2012, 16:17 -
Playstation 2 plays games & DVD-Rs, but craps out on bought DVDs
By JustPlainDon in forum DVD & Blu-ray PlayersReplies: 3Last Post: 29th May 2008, 17:58 -
Store bought DVD movies rarely play
By Mark Girvan in forum Newbie / General discussionsReplies: 7Last Post: 16th Jan 2008, 13:12 -
Trying to rip scenes from a store bought DVD...no dice
By Huntr777 in forum MacReplies: 2Last Post: 4th Nov 2007, 07:14 -
scenes missing from store-bought movies
By johnsees in forum Newbie / General discussionsReplies: 11Last Post: 19th Oct 2007, 15:53
