Hi,
I am trying to transfer a track from a CD but when I select project import audio a message appears
Audacity cannot open this type of file, Convert it in a format that audacity can import. What does it mean?? Thanks/Fabio
There is a "quick tour" in the CDex's help system.
Basically...
Put the CD in the drive
Select the drive (if it didn't find it by itself)
hit the "magnifying glass" to have it find out what CD you have
Press either the "extract to WAV" (first button) or "extract to Compressed (MP3)" (second button)
and watch it work.
You will end up with a bunch of files that are editable in Audacity.
Does anyone know how to use Clipfix with Audacity?
By snafubaby in forum AudioReplies: 4Last Post: 29th Jan 2011, 06:37 -
Audacity help
By efiste2 in forum AudioReplies: 3Last Post: 5th Aug 2010, 13:59 -
need some help with audacity
By shashgo in forum AudioReplies: 7Last Post: 16th Jan 2009, 01:21 -
audacity and mp3's?
By tchambers in forum AudioReplies: 9Last Post: 6th Dec 2008, 20:21 -
Audacity question
By Jeikobu in forum MacReplies: 2Last Post: 23rd Aug 2007, 10:57
