I often get that error:
what does it mean?*** Post Verification ***
Addresses in VMG IFO does not match the actual file sizes
Addresses in VTS IFO does not match the actual file sizes
[ERR] Post verification fails - 1999
Sometimes if I try to compile again with SAME audio+video files it works fine...
MYSTERY...
help plz!![]()
maybe this helps anyone who experienced problems like these (like I did). I used another computer and this error was gone :S, initially I thought making the links to the movies easier (the direct playable in the main menu first, the ones within submenus as second, third etc. in stead of the reverse order) solved the problem, but the old version somehow worked as well (maybe some slight changes like changing return menus).
Dvd Lab Pro 2.5 Pre Verification fails / Compile.aux error
By Ultron in forum Newbie / General discussionsReplies: 3Last Post: 29th Aug 2010, 22:45 -
DVD Pro Lab - Error: Read Data Size
By lapetite_66 in forum Authoring (DVD)Replies: 2Last Post: 23rd Jul 2009, 15:48 -
DVD Lab Pro Error
By SirEdward in forum Newbie / General discussionsReplies: 5Last Post: 4th Aug 2008, 17:22 -
DVD Lab Pro Error b4 compiling
By _yoyo in forum Authoring (DVD)Replies: 1Last Post: 20th Apr 2008, 19:39 -
dvd lab pro audio error
By tomoftenville in forum Authoring (DVD)Replies: 7Last Post: 6th Dec 2007, 17:05
