Hi all,
This is my first post here.
I would greatly appreciate if someone could enlighten me on whether it is true that NTSC/PAL is not applicable for VGA output.
I am asking because I have an NTSC plasma display monitor on which I wish to play PAL dvds. A retailer told me that if I send my PAL video input through an external TV tuner box l would be able to display it through the VGA connector to my plasma screen.
I had earlier bought the Pioneer DV393-S dvd player which has a built-in PAL-NTSC converter but found that the picture still suffered from judder.
Thanks for any help.
It is true that VGA has no format (PAL/NTSC). I am not surprised that you get judder from converting. The only way to get true NTSC/PAL playback is to get native output. That is NTSC in : NTSC out. PAL in : PAL out.
What you should have bought was a multi-format capable TV.Read my blog here.
Originally Posted by guns1inger
It also came bundled with an external TV-tuner which was working fine (even for PAL dvds) until just a couple of days ago when the judder problem appeared. I wasn't sure if it was the plasma or the tuner that had gone out-of-whack. Hence I decided to take the safer route by buying the Pioneer 393 instead. Unfortunately that didn't solve the problem so I may have to consider getting another TV tuner box.
vga output has stopped working and I don't know why
By xtube in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2010, 02:33 -
cant output 1920x1080 through vga
By sitlet in forum ComputerReplies: 13Last Post: 27th Jan 2009, 17:34 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 14:36 -
PAL VCR with true NTSC Output (not PAL 60)
By Area88 in forum RestorationReplies: 31Last Post: 12th Aug 2008, 17:55 -
Premiere PRO - NTSC DV to PAL MPEG output
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2008, 12:06
