At Compusa.com
Apple iMac Desktop
Intel Core Duo 2 Processor, 2.16GHz, 1GB RAM, 250GB Hard Drive, 8X DVD+/-RW SuperDrive, Built-in 24-inch LCD Monitor, Mac OS X Tiger v10.4
- Product Number: 341876
- Mfr. Part #: MA456LL/A
- Brand: Apple Desktop PCs « Visit their Showcase
Monitor not included unless otherwise specified.
- Rating: Read all 2 reviews $1,999.99
HP Pavilion m7680n TV Minitower
Intel Viiv Technology, Intel Core 2 Duo Processor E6400, 2.13GHz, 2GB RAM, 500GB Hard Drive, 16X DVD+/-RW and 16X DVD Drives, Windows XP Media Center 2005
- Product Number: 339557
- Mfr. Part #: RC647AA#ABA
- Brand: HP Desktop PCs « Visit their Showcase
- Rating: Read all 7 reviews Was: $1,229.99
$1,179.99
Not quite twice the price but if you factor in the HP has twice the memory, twice the hard disk, and twice the speed DVDwriter, looks like LordSmurf is right.
Oops I missed the monitor for the HP
HP w22 22-inch LCD Multimedia Monitor
- Product Number: 341925
- Mfr. Part #: RG556AA#ABA
- Brand: HP « Visit their Showcase
Be the first to write a review $429.99
Looks like Apple is 25% more for less hardware.
Results 61 to 73 of 73
Yeah but the problem here is most people do not build their own systems. Most people buy a new system. They use it for 5 - 10 years and when it breaks or gets old move onto something new. The general population use computers as appliances, like a DVD player or TV.Know your audience. These aren't all the Best Buy sale of the week lemmings. Many can and have built their home machines.
Vista will be the thorn for the home builder. MS has back tracked from the install once thorn with the retail version but they are still unclear about how many times you can install Vista. -
You haven't seen my "Pimp my Celeron to Core2 Duo" project, currently $448 out of pocket ($600 with new OS). Most here can recycle existing parts.Originally Posted by RLT69
https://forum.videohelp.com/viewtopic.php?t=311893
PS: what is the need for an expensive videocard or 667 MHz DDR2 RAM when 533MHz is enough? -
I stand corrected. Does it have racing stripesYou haven't seen my "Pimp my Celeron" project, currently $448 out of pocket ($600 with new OS). Most here can recycle existing parts.
https://forum.videohelp.com/viewtopic.php?t=311893&highlight=pimp
You are missing the point. The point is don't blow all your budget on Core2 Duo when Quadro will be here in January. Consider Core2Duo a transition project and keep your powder dry.
Lets try this system for comparison a bit cheaper with a smaller moonitor than Apple - still more memory, HDD, TV-tuner and PVR, a printer/scanner and faster DVDwriter. 40% less if my arithmetic is correct.
HP E6400 Media Center with 17" Flat-Panel LCD Monitor & 3-in-1 Printer
Save $180 instantly on this premier Media Center PC package (m7674n, vs17e, C3180). Best Buy exclusive!
Thanks to a next-generation processor, Intel® Viiv™ technology and built-in TV tuner and wireless LAN, you can take your digital entertainment and games to the max!
Intel® Core™2 Duo processor E6400, 2GB PC2-4200 DDR2 SDRAM; Windows XP Media Center 2005, TV tuner/PVR, LightScribe-enabled DL DVD±RW/CD-RW drive, 400GB SATA hard drive, NVIDIA GeForce 7300 LE graphics, 15-in-1 media reader, wireless LAN
17" flat-panel LCD monitor with a slim, clean design and integrated speakers to reduce clutter; ultrafast 8 ms response time, 500:1 contrast ratio, antiglare screen and tilt control
Photosmart 3-in-1 printer, copier, scanner with auto paper-type sensor and built-in memory card slots for PC-free photo printing
Save $180! (Reg. price $1439.97 - $180 total bundle instant savings = $1259.97) -
Yep,
http://www.anandtech.com/mac/showdoc.aspx?i=2832&p=1
You can also upgrade the Mini's processors, not sure about the iMac. And no, you can't upgrade the Laptops... yet.
It's a whole new ballgame :P -
I don't really see that as an option for the laptops. The MacBook Pros basically come with a 2.33GHz Intel Core 2 Duo.Originally Posted by jagabo
For the desktops I can choose fromSo am I to understand I'll see the most dramatic increase in the speed of video conversions with that 3GHz dual-core xeon regardless of how much ram I have?Two 2.0GHz Dual-Core Intel Xeon
Two 2.66GHz Dual-Core Intel Xeon [Add $299]
Two 3.0GHz Dual-Core Intel Xeon [Add $1098]
The only thing is, I'm much more likely to buy a laptop than a desktop. Am I basically stuck with it's relatively mediocre video processing power? When I run 5 Adobe graphics programs at once on my current computer, I notice some lag. -
A couple of points to consider:
The benefit of a quad system (i.e., 2 x duo) will depend greatly on the software and how well it has been written to make use of all the available CPUs.
As more and more graphics cards sport programmable GPUs, software solutions will gradually make use of that allowing intensive, repetitive calculations to be performed by the GPU instead of the CPU. In such circumstances, the choice of graphics card could start to be more of a deciding factor in video editing environments.John Miller -
Now you didn't just say "533MHz is enough" did you. Let's discard the, "that's enough <insert spec here>" comments. Besides we are talking $5 dollars more.PS: what is the need for an expensive videocard or 667 MHz DDR2 RAM when 533MHz is enough?
$100 for a video card is not expensive when you are talking about spending $200 on a processor. Besides your point was a system that can blow you away.
If you want to save money go with AMD, their processors are cheaper and AMD has new multi processor boards coming out, their 4 x 4 platform. You can have two quad processors. Nice 8) -
AMD quad core processors won't be available until the spring. Intel will have quad core processors and dual CPU Xeon motherboards to put them in in a week.Originally Posted by RLT69
OK, we are debating as as means to learn more about Core2 Duo.Originally Posted by RLT69
Core2Duo FSB is 1066 MHz. PC2-4200 (533MHz) DDR2 runs synchronous to Core2 FSB and Dual Mode gets 1066MHz.
Non sync PC-5300 (667MHz) won't run as fast according to some tests unless the FSB is overclocked in Dual Mode configuration which can be risky with current motherboards.
Ref: http://en.wikipedia.org/wiki/Intel_Core_2 "DDR2 Memory Modules"
PCIe video cards aren't ready for video prime time IMO so I want to spend as little as possible until full h.264 1080p hardware decoding is offered. Currently you need the ATI x1900 @$200 to have a shot at h.264 1080p and that with substantial CPU load.
http://www.extremetech.com/article2/0,1697,1916993,00.asp
Future cards will fully hardware decode MPeg4 AVC plus offer encoding assist for MPeg2 and MPeg4. I'm saving my money for one of those and living for now with an old ATI 9550 (AGP) or x1300 (PCIe)(both ~$45) for HDTV out.
http://www.newegg.com/Product/Product.asp?Item=N82E16814125027
The x1300 is good for hardware (+ software assist) 480p H.264 decode.
HELP! Capture with MAC but I need to edit with a PC!
By blainedepue in forum Video ConversionReplies: 2Last Post: 27th May 2009, 11:39 -
Use a MAC to capture...Use a PC to edit? Help!!!
By blainedepue in forum Video Streaming DownloadingReplies: 1Last Post: 27th May 2009, 03:43 -
How can I transfer CCD V5000 Hi8 Analog Video to digital/MAC to edit?
By thebird in forum Newbie / General discussionsReplies: 0Last Post: 15th Apr 2009, 05:36 -
Capture DV with PC/Edit on Mac with FCP????
By mkoplin in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2008, 20:33 -
best format to edit on a mac
By devdev in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 00:07
