B/C of some issues with Nero that I was using I had some other program problems and had to uninstall and reinstall (and Reg) clean Any Dvd.
I did a properties check and my External Benq is working ok, however for whatever reason when I did my d/l the Any Dvd is only recognizing my internal drive D as Default and i had always been burning with my External BenQ.
I checked in My Computer and it is shown there but when i put in a video to back up of course the Any Dvd is not working on that drive.
I don't know how I ended up with my internal D drive as my default, I must have changed something and I would like to get my BenQ back as my default drive.
I hope that some member can help, thankyou.
Toshiba Satellite M50-MX 5
1.8ghz, 1 gig RAM,Intel Pent 4, xpsp2,
BenQ 162I 16X External Burner
Western Digital Storage Device 160 gigs -
I thought that I should post b/c I did figure it out, I had to disconnect the power and wait several seconds and reconnect and now everything with Any Dvd is ok for both external and internal drives.
All the headaches that I have had with simply trying to uninstall Nero 6.6.0.18 using their Tools for cleaning which I had a horrible time getting to d/l without disconnecting my Router and as well my XP, sp2 firewall just to get the d/l's; neither of which made me feel comfortable.
I don't like a program that needs you to go to the internet to get their tools to do a clean uninstall, I normally use add/remove and a Reg clean and do a Search after that to see if there are any leftovers.
This will be the last time that I install Nero as I have read in other forums about members having similar problems. But when I go to the actual Nero forum, every that posted claimed I was the only one that had such problems.
After the d/l of the Tools, and then the use of the Tools to rid of Nero I had several programs get corrupted and then my external burner acted up with Any Dvd which I had posted here for a solution, however I found it myself by fiddling around.
I am going to do another post in software and ask for members experience in their use of Nero and uninstall and install and the d/l of the tools to do the former.
Thankyou.Toshiba Satellite M50-MX 5
USB External Burner Problem- help?
By Super Warrior in forum ComputerReplies: 1Last Post: 3rd Jun 2009, 23:50 -
Benq EW162I DL burner Problem
By wanghiking in forum Authoring (DVD)Replies: 9Last Post: 20th Nov 2008, 20:09 -
Which Benq DVD burner is the best
By Habby in forum DVD & Blu-ray WritersReplies: 1Last Post: 12th Oct 2008, 13:43 -
having a problem with my Mad Dog external DVD Burner
By Bamahusker in forum DVD RippingReplies: 26Last Post: 18th Nov 2007, 11:53 -
External case for my BenQ W1640
By bluemoss in forum DVD & Blu-ray WritersReplies: 7Last Post: 15th Nov 2007, 16:09
