Hello, I'm new to these forums. I know how to burn a vcd using MainConcept but I'm having trouble burning a large sized movie. Eg. I try to open 'XMEN_3_The_Last_Stand', when I click open I get this "No video data found". I read the MainConcept guide and it mentions VFAPI converter and VirtualDub but doesn't tell me exactly how they help to load my movies.Please help. I'm sorry if this type of help has been asked before. Thanks.
umm... thanks?
I got 0 results from all the text I entered having to do with my issue. Anyone else have some advice? -
What you need to do is go and buy the DVD, so you know you have sound source. Failing that, use g-spot to work out what codec you need to be able to open the files you have acquired.
In almost all cases now, any guide that recommends VFAPI is very out of date, and better methods will exist.
You also need to understand that while your specific question might not be answered in a guide, usually you will find all the parts to the question answered, You just have to work out the answer.
I would suggest you start with FitCD, avisynth, Mainconcept, and g-spot, and work from there.Read my blog here.
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 18:14 -
Some Mainconcept MPEG Encoder questions.
By scott274 in forum Video ConversionReplies: 9Last Post: 15th Jul 2008, 03:08 -
MainConcept MPEG Encoder 1.5 question
By hanugro in forum Video ConversionReplies: 6Last Post: 21st Feb 2008, 20:27 -
Avi to DVD (mpeg2) in Mainconcept Mpeg Encoder, basic how to
By reboot in forum User guidesReplies: 31Last Post: 6th Aug 2007, 15:56 -
MainConcept H.264 Encoder Error
By cowboysroy31 in forum Newbie / General discussionsReplies: 0Last Post: 22nd Jun 2007, 19:06
