I was playing around with Premiere Pro 2 and After Effects 7 trying to create a mask of a princess leas head in a scene from starwars so I can eventually put someone elses head in her place.
I was able to, in after effects mask out only her head but there arent enough nodes to accurately select the shape I want to mask. For example in photoshop you can click as many points as you want on a photo to cut out exactly the shape you need. But when working with video I only am allowed a circle or 4 points and that doesnt let me pick with any accuracy what I want.
I figured for my task I would mask out the head using keyframes as the video moves to keep only what I want in the scene and then add my video over and scaling it to fit.
I could do what I want if was masking out a square but the mask tool doesnt seem to let me pick more than 4 nodes to create the shape I need. I can do it with a still picture but not with video.
Can anyone help or point me to a guide on this?? ( I actually have Vegas 5 if that is easier but have access to premiere pro 2 and after effects 7 on a different PC and they are what I was trying this on).
Hi Rudyard,
I don't know if you've ever come across www.wrigleyvideo.com/videotutorial - it's a great site for Adobe video-related s/w that may well have the answers in the forums. If not, you can register and ask.
Good luck!There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thanks Daamon, I have been directed to that site before - will have to bookmark it so I can use it for reference!
Didnt know it had a forum and will hopefully learn some tricks there.
Thanks for your help. -
If you are restricted to four nodes you are using the wrong tools.
One of the best free sites for effects and video tutorials is the creative cow. Lots of AE stuff as well as many other packages.
http://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=2&page=http://www.creat...ts_script.html
will get you started. You might want to look at the podcast on motion paths and how to create you paths in photoshop and import them for masking.Read my blog here.
Use the pen tool. You can shape whatever you want, and I believe you can also add or delete nodes through the video.
You can add nodes...You can move the mask, reshape the mask, etc...It simply represents an extra keyframe under the "mask" properties of your layer...
Just to push you into the right direction...If you're looking for fancy masking, google "rotoscoping"...
Unfortunately you haven't opened up the treasure box that masking allows for..
how to replace a head in a video with my own?
By bigtime1957 in forum Newbie / General discussionsReplies: 12Last Post: 11th Nov 2011, 12:34 -
I'm scratching my head - I just want to do simple video conversion?!?!
By Matt_C in forum MacReplies: 6Last Post: 9th Jan 2011, 21:26 -
Looking for a filter to mask out white specs in video...
By Deter in forum RestorationReplies: 8Last Post: 2nd Aug 2010, 13:36 -
Best way to Mask out Betamax video dropouts using hardware?
By Deter in forum RestorationReplies: 3Last Post: 10th Mar 2010, 11:02 -
Video head cleaning & capture
By MTD in forum Newbie / General discussionsReplies: 8Last Post: 9th May 2007, 19:56
