PHILIPS DVP3150V
I noticed there are no hacks. Can I use one from the model above? I used to have a Japanese DVD that played all regions no codes involved, it was great, went thru 2 of them as they seemed to have a self destruct mode after so long.
Anyway, I need a code for the above model. As I am new, do I just get info off the computer and point and click or do I have burn something then load it into the machine?
Any help would be greatly appreciated!
vicrine
You could try this one, you never know, it might work. https://www.videohelp.com/dvdhacks.php?select=Philips+DVP+3100V
I take no responsibility if it breaks your player.He's a liar and a murderer, and I say that with all due respect. -
You also need to keep in mind, that if it does break the player, not only will steveryan not be responsible, Philips won't help you either.
If it is that important, try buying a region free player.Google is your Friend
Victor DVD player hacks, no where to be found?!?!!?
By hiko in forum DVD & Blu-ray PlayersReplies: 3Last Post: 23rd Dec 2010, 22:55 -
DVD Record-Player firmware/hacks
By wguru in forum Newbie / General discussionsReplies: 1Last Post: 29th Dec 2008, 12:53 -
Question about hacks
By Asmodee in forum DVD & Blu-ray RecordersReplies: 0Last Post: 16th Jan 2008, 12:36 -
Dodge/Chrysler DVD Player - any hacks for region codes?
By paulfnyc in forum DVD & Blu-ray PlayersReplies: 2Last Post: 6th Nov 2007, 09:35 -
beware of DVD player hacks scams
By lordsmurf in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th May 2007, 01:33
