I'm trying to get the best possible audio for capturing but it sounds like crap. I have the mic wire from the ATI AIW "purple pod" going into the back of my Soundblaster. Is the mic just generally bad for sound quality? Is there another way to hook the video card up to the SB? I notice there is a little white 4 pronged connector on the ATI, what is this for? I don't have any cables that fit it and it doesn't look like it matches any of the ones on the sound card.
AMD ATHLON XP 1700+ CPU
ABIT KR7A-R MOTHERBOARD
512MB PC2100 RAM
SONY 21" TRINITRON CPD-G520 MONITOR
ATI ALL IN WONDER RADEON 8500DV 64MB NTSC
ENERMAX FS-710BB 330W FULL TOWER CASE
SONY SPRESSA 16X/10X/40X EIDE INTERNAL CDRW
CREATIVE LABS SOUNDBLASTER LIVE! PLATINUM PCI 5.1
SONY 16X DVD INTERNAL EIDE DRIVE
IBM 60GB 7200RPM HARD DRIVE
KLIPSCH PROMEDIA 5.1 (500W) SPEAKERS
I'm not sure if you typed one thing and meant another, but your post implied that you hooked your capture box to the 'mic' input of the sound card, whereas it should probably be hooked up to the 'line in' on the soundblaster. If that's the case, it should sound a lot better by switching to the 'line in'.
-matt
My New WD TV Live having audio issues with M2ts files
By jbitakis in forum Media Center PC / MediaCentersReplies: 8Last Post: 7th Dec 2011, 19:06 -
Sound with ATI AIW 9800 Pro
By andrewjameshoward in forum Capturing and VCRReplies: 1Last Post: 8th Aug 2010, 07:02 -
ati 8500dv resource problems
By jwdove in forum Capturing and VCRReplies: 1Last Post: 27th Sep 2009, 13:48 -
Remove the sound buzz in Vegas Studio Platinum
By Cazz in forum EditingReplies: 3Last Post: 19th May 2009, 13:54 -
ATI Aiw card in Linux?
By Nelson37 in forum LinuxReplies: 9Last Post: 10th Apr 2008, 14:25
