I have the WinFast XP2000 capture card in my computer, my question is.... is it possible to put a second capture card in my computer aswell. Will 2 Capture/Video cards effect the performance or contradict each other in any way when i use them. I will only be using one at a time and never both together. It's just that one will have a VCR connected to it and the other a Satellite receiver. It's easier to have 2 cards rather than connect and re-connect cables at the back when i wanna change the input from VCR to Sat receiver.
Thanks.
I have never done it myself but you should have no issues. Though I think it would be best to capture each one to a seperate hard drive.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Question about Winfast card & Hauppauge software ??
By VEBouto in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 11:03 -
Looking for new driver for video card- MEDION (7134) WDM Video Capture card
By 2prfm.com in forum Capturing and VCRReplies: 3Last Post: 15th Sep 2008, 03:48 -
Question about software for K-World Video Capture Card
By cooper101 in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2007, 14:49 -
Problem with WINFAST TV2000 XP Expert tv capture card.
By trueman in forum Capturing and VCRReplies: 1Last Post: 5th Aug 2007, 12:00 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
