I have a Toshiba 30HF85 HDTV, and have never been thrilled by the picture. It's always been dark, and increasing the brightness only washes everything else out. Contrast is maxed out. Also, it's supposedly in 1080i mode, but the picture just doesn't seem to be that sharp. Sharper than regular TV, but, for example, graphic and scores on sports broadcasts just aren't "crisp." I'm using component cables - would HDMI substantially help? Is there anything I can do to calibrate or adjust the TV beyond the normal menu options? Am I just expecting too much?
What is the source material that you using to compare the sharpness? If your only source of comparison is cable and DVD, then you are not truly using HD.
Google is your Friend -
You should be seeing better than that. It sounds like you are running your cable box in 480i mode or watching SD channels. Try adjusting the TV using the THX signal on a laser disc. If the TV can't be adjusted for full gray scale, it needs to be taken in for "internal" adjustment. CRT sets loose brightness as they age, internal adjustments are needed to brighten it up.
http://www.thx.com/mod/products/dvd/optimizerIntro.html
New 37 in. Toshiba HDTV, can't turn off closed captions
By G Emond in forum DVB / IPTVReplies: 7Last Post: 15th Feb 2009, 00:32 -
HDTV gives stuttering picture
By thrilled in forum DVB / IPTVReplies: 13Last Post: 18th Nov 2008, 08:30 -
watching avi from my pc to toshiba lcd hdtv
By goo2 in forum Software PlayingReplies: 6Last Post: 21st May 2008, 21:19 -
Toshiba HD-A2 or HD-A3 wich gives the Better Picture?
By ofield1 in forum DVD & Blu-ray PlayersReplies: 16Last Post: 7th Mar 2008, 12:23 -
Problems with connection with my Panasonic HDTV and Timewaner HDTV box...
By S4one in forum DVB / IPTVReplies: 7Last Post: 2nd Nov 2007, 23:39
