I have downloaded an avi file, where audio is always delayed by around 6 seconds.
Is there a simple way to fix this?
I have access to the DVD ( from which this avi was created ) as well, which is a RIP from a VHS tape.
Following is some info about the file from VLC media player.
Stream 0
Codec - XVID
Resolution - 336x256
Frame Rate - 29.970030
Stream 1
Codec - mpga
Channels - 2
Sample Rate - 48000 Hz
Bitrate - 109 kb/s
Length of Video - 2:32:26
Extract the audio with a program such as goldwave, remove approx. 6 seconds from the beginning of the file, then encode with virtualdub.
Google is your Friend -
You can simply remultiplex the audio and video with VirtualDub and set a -6000 millisecond audio delay value to advance the audio by 6 seconds.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
Problem with one delayed audio stream
By ne0n in forum Newbie / General discussionsReplies: 0Last Post: 24th Jan 2011, 13:28 -
SOLVED: Audio out of sync or no audio - mkv/h.264 to avi/xvid
By dwoozle in forum Video ConversionReplies: 3Last Post: 2nd Feb 2009, 17:14 -
Audio got delayed
By qknet in forum Authoring (DVD)Replies: 3Last Post: 30th Oct 2008, 03:09 -
Converting AVI to xvid AVI - Audio Sync Problem
By foochuck in forum Video ConversionReplies: 3Last Post: 5th Jul 2007, 00:22
