    Nov 2006
    Dear all,
    what exactly are the limitations of the trial version of ffmepgX ? I'm testing this software before deciding on buying it. I was able to convert a 1 hour mpeg2 video to DV with no problems. However now, when I tried another one of one hour, the resulting DV is only 20 minutes or 4GB instead of 12 GB. Even when I try the first mpeg2 I converted successfully before. Is this a limitation of the unregistered version or a bug ?
    Thanks,
    Nick,
  2. It is not a limitation. Are you using the "Decode with Quicktime" option (in the options tab) or not?
    Nov 2006
    I do not see that option under the option tab. I'm using version 0.0.9
  4. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    It is circled in this screenshot.
    The first v0.0.9 is from three years ago. The current version is 0.0.9x r2 from 2006-10-02.
    Nov 2006
    I have version 0.0.9 r2 actually.
    That option is not visible on my screen. There is just an empty space there.
    Nick,
  6. Begin by selecting the "DV" quick preset and then the option will appear.
