  1. Hey all, I just got a new computer as you can see in my sig. I've encountered a major problem though. My cable provider uses two cables, an A and a B to go to the cable box. One is for channels 1-62 and one is for 63-120. To add to that problem, the channels are scrambled, so if I hook my computer up to just one of the cables, I can't get any channels, not even the local ones. I hope there's a way I can use my tv card directly with the cable, otherwise I won't have a use for this nice remote that came with my TV card. Any ideas??
    _________________
    AMD ATHLON XP 1700+ CPU
    ABIT KR7A-R MOTHERBOARD
    512MB PC2100 RAM
    SONY 21" TRINITRON CPD-G520 MONITOR
    ATI ALL IN WONDER RADEON 8500DV 64MB NTSC
    ENERMAX FS-710BB 330W FULL TOWER CASE
    SONY SPRESSA 16X/10X/40X EIDE INTERNAL CDRW
    CREATIVE LABS SOUNDBLASTER LIVE! PLATINUM PCI 5.1
    SONY 16X DVD INTERNAL EIDE DRIVE
    IBM 60GB 7200RPM HARD DRIVE
    KLIPSCH PROMEDIA 5.1 (500W) SPEAKERS
    <font size=-1>[ This Message was edited by: MikeS on 2002-01-13 16:12:34 ]</font>
    <font size=-1>[ This Message was edited by: MikeS on 2002-01-13 16:18:05 ]</font>
    Feb 2001
    Palmdale, CA
    put a splitter on the output of your box, that is about your only option or get another box for your puter, about your only choice.
