I have lots of AVI-films on my harddisks (38 years of filming in different formats but now AVI). They are edited with Ulead6 and later Pinnacle 9. A couple of years ago I found a good Sonic4 program to make DVD's However it suddenly gave error messages and I tried to reinstall but finally gave up and bought Sonic8. This was not what I had expected with very limited menus and not at all as Sonic4.
I have now tried some of the programs I have on my PC and found the following:
Nerovision express 3 cannot create music with the Menu. Does anyone know if a later version can add music to the menu?
Pinnacle studio 9.4.3 does not work with creating a DVD. I have tried creating a DVD but it never finishes. I made a test with 4 minutes but after 5 hours I think something is wrong with the burning so I stopped it.
I have never been able to use this Pinnacle 9 for burning but I would not dare to buy Pinnacle 10 as Pinnacle donot have a trial version on the net that can be downloaded. One can not even buy it on the net and download.
Is there anyone who have had problems with Pinnacle 9 for burning?
If you have burning problems you could always tell it to just author the video_ts folder and use another app to burn. If it has iso as on output that would be the easiest to use another app or use a freeware iso creator program then burn with that.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
