I download Japanese subtitle SRT. When I open it with notepad, it appear mess up. I mean It is not japanese, can't read.... I don't know how to show correct japanese.
i Setup UTF-8 and UTF-16, but it won't fix. How can I fix???
I have japanese font in my XP. I can read Japanese in email and write japanese
you might try installing subtitle workshop and see if you can open it there. Are you trying to edit the subtitles?
You are in breach of the forum rules and are being banned. Do not post false information.
/Moderator John Q. Publik -
I installed workshop subtitle, but still I can't see japanese correctly.
I don't edit, just want to put on video and burn DVD with convertXtoDVD.
I don't know why, because I can read email without problem..... -
I'm not sure if notepad is able to show UTF-8 / 16 correctly. Try it with a better editor like word, open office or at least Wordpad
GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Maybe it's not in Unicode format. I can speak Russian and Cyrillic characters can be written on computers with Unicode, CP-1251 (Windows PCs), KOI8-R (usually non-Windows computers), and a few other things. To rip Russian subtitles, I had to change the code page of my PC to CP-1251 and then run SubRip. Nothing else worked. I don't think any subtitle programs that can rip or convert subtitles understand Unicode, so perhaps the file is in some other code page that supports Japanese such as ISO-2022-JP or something similar.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
