I can't figure this out. I have a 701MB (un-zipped) xvid file sitting in My Documents.
When I try to create a VCD with this file using Nero 7 and a 700MB 80Min. CDR, as soon as I add it to my project and get to the burn screen, it gives the following message:
Problems may occur when burning the project. Total space used: 946.2 out of 703.1 MB.
How did I end up with a 946MB file when I started out with an un-zipped 701MB file?
Not the first time this has happened with 696-701MB xvid files.
On the other hand, today I burned a 1.38GB 2 CD file, which showed as 700 and 698 MB files (un-zipped) in My Documents folder, but when created as VCD with Nero showed as 547MB or so each when added to project. No problem burning them.
Unfortunately I don't have a DVD burner yet so I'm limited to 700MB CDR/CDR-W using xvid in order to allow them to be played on TV using a stand alone DVD player. Really don't want to be limited to viewing on my pc.
Anybody clue me in?
Results 1 to 10 of 10
Converting to a VCD is different to just burning an Xvid. VCD is governed by strict compliance guidelines, so really only running time influences the size, regardless of how big it was to begin with.
Are you converting all of these to VCD, or burning as data ?
Have you tried alternative burning software ?Read my blog here.
I have only burned them as VCD (using two different versions of Nero), as my standalone DVD player in the family room will not play them if I burn them as data.
Could you suggest any alternative burning software?
I understand what you are saying about running time vs. file size.
I've been wondering if I can split the larger files myself to fit on 2 CDR's.
I will be so glad when I am able upgrade my PC.
Thanks for any help you can provide..... -
For your convenience: Click here.
/Mats -
Thanks very much guns1inger and mats. Looks like I'm headed in the right direction now.
Very glad I found this forum
FYI depending on your budget you can get a brand new 16x internal dvd burner for around $35 plus shipping at places like newegg and tigerdirect online. Well worth the upgrade and you won't regret it
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
That will have to be the way I go for now, since I can't upgrade my archaic system right now.
Didn't realize they were that inexpensive. I'll definately check that out, sounds like it will make my life easier!
By the way, do members have ability to view each others CPU specs? (IE: To advise on compatibility issues,etc.)
Thanks yoda!"I do not fear computers. I fear the lack of them." -
Yeah put your mouse over the "computer details" button on each post people make. Not everybody has their details filled out however.
Good luck on the dvd burner front. I bought my pioneer 111d dual layer burner 16x for $35 plus shipping at newegg a few months ago and love it. Great buy.
Yes, there's a "computer specs" button above each post, that shows what the user has filled in in his/her profile. Unfortunately, many ignore filling these things in, but they can be a great help, not having to ask for what OS/CPU/etc we're dealing with.Originally Posted by Slider4073
/Mats
How to split a .TS video file based on time (not file size!) ?
By Michael REMY in forum EditingReplies: 4Last Post: 19th Sep 2020, 19:32 -
Burning a CD -- Minutes vs. File Size
By Opv in forum AudioReplies: 17Last Post: 5th Mar 2011, 23:55 -
Help converting small size but large stream size asf video stream file?
By apple4red in forum Video Streaming DownloadingReplies: 5Last Post: 11th Oct 2010, 12:01 -
Verbatim 94554 CDR vs. 94712 CDR. What's the difference?
By Puppets86 in forum MediaReplies: 12Last Post: 3rd Oct 2010, 17:31 -
Question about burning file size
By magikero01 in forum Newbie / General discussionsReplies: 7Last Post: 3rd Jan 2008, 08:34
