I just ripped my very first DVD using Mac the ripper software. It created 3 folders: AUDIO_TS, JACKET_P, VIDEO_TS. Here is my question: How do I play the movie? I don't want to copy to a new DVD, but run it on my MAC. I've tried to run one of the files in the JACKET_P folder with an .MP2 extension. Quicktime gives me an error msg and so does the real player I have installed. I'm using Quicktime version 7.1.3
What am I doing wrong?
You should be able to play the VIDEO_TS folder, which is where the DVD video is. I would try the Mac version of VLC Media Player for that.
Under 'File', select 'Open Directory' and choose the VIDEO_TS folder. Or you may just be able to click on the folder and see if 'Play with VLC media player' is available as a choice. It should give you all the menu choices and play just like the original DVD.
And you might want to ask Mac specific questions in our Mac forum to get more responses. Moving you.
And welcome to our forums.
Also more natively:
Launch DVD Player.
Select under the File menu
"Open DVD Media".
Navigate to the ripped output of MTR
( the video TS folder) and select it,
click ok.
Push the Play button on the DVD Player control bar."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
U R welcome.
Urban Mac User -
Now that I am backing up my dvds using mac the ripper to toast 7 or popcorn i have ran into troubles with bad sector or some files might be corrupt after ripping? How do I open them and remove before I send to Toast or Popcorn to back up. Most of my dvd's have ripped and burned fine? Just a few new ones I am getting errors?
DVD ripper for Mac
By tee jay in forum DVD RippingReplies: 1Last Post: 28th Feb 2012, 10:48 -
Ripping a Region 2 DVD on a Mac Book Pro with Mac The Ripper
By Jess021 in forum MacReplies: 7Last Post: 17th Nov 2011, 06:04 -
I'm an idiot! How do I copy a DVD using Mac The Ripper and Toast 10?
By brido7760 in forum MacReplies: 2Last Post: 20th Jul 2009, 12:42 -
Is there a dvd ripper for Mac?
By reddeviljp in forum MacReplies: 9Last Post: 15th Aug 2008, 03:10 -
Burning dual layer dvd-r from mac the ripper
By alforra in forum MacReplies: 11Last Post: 18th Apr 2008, 22:08
