I want to add a subtitle to a avi file in order to play it on a standalone dvd player.
I have a avi file encoded in divx 5,and the subtitle in different formatssa,srt.
Results 1 to 18 of 18
standalone divx dvd player? then it may be enough to just add the avi and srt on the cd and name them like video.avi and video.srt
any standalone dvd player? then use ConvertXtoDVD, add the avi and srt and make a DVD. -
Adding subtitles externally does not work,I tried to mux using SubMux v2.23 from Gabest and AviMuxGui,i tried ConvertXtoDVD but i have a problem when I add the ogm or mkv file it does not see the subtitle streams if I add avi the file it does not see the audio streams.The only option i see is adding the sub permanently.I tried to add using VirtualDubMod and the Subtitler.vdf plug in from Avery Lee but it takes 5h to re encode.Do you know a program or a way to do it faster.
Or to stop and resume tomorrow. -
i have same problem too. followed administrator's Guide using VirtualDumMode in ogm to avi but its taking me soooo loooong and sooooooo big an output.
also tried SubMux but i got ERROR when playing them.
tried AviMuxGui, audio is OK but there's no subtitle.
haaaaaay....
please help...
You are in breach of the forum rules and are being issued with a formal warning. I've asked you twice to fix your sig pic to keep it within rules. Do it now!
/ Moderator mats.hogberg -
it's taking to long, and making a big file too, because you are making an uncompressed video file.Originally Posted by ross_diadame
you must change the compression type and select another video compression codec, other than the default (uncompressed RGB) and also do the same for the audio -
here some steps
1. open avisub
2. push button "Load Avi"
3. check checkbox "Delete Temp Files"
4. push button "Load srt...."
while message box about "line too long" appears
select smaller "font size"
goto step 4
end
5. if all ok press button "Generate subbed avi"
when it finishes you have a playable .divx file
burn it and play it on dvd player
choose desired subtitle
thats all -
unfortunately ann error occurs.
i dunno why?
anyways, i quoted this from maya chan in http://forums.3ivx.com/ and currently trying now.
still editin the sub cus it has so many /N.
[quote](I had 4 folders to stay oranized 1. for video(no sound or subs) one for audio one for subs and one for final avi's)
1. open ogm file with VirtualDubMod
2. go to streams list
3. Demux 2nd Audio (Japanese)(saved as ogg)
4. Demux subs (saved as srt)
5. disable all streams
6. file->save as whatever the show is (kenshin 1)(direct stream copy)
7. open srt with vobsub's subresync
8. Save as same name but as a ssa
9.open program ace-high mp3 wav wma ogg converter
10. convert audio ogg to wav file
11. reopen virtualdubmod
12. open the video you made with everything disabled (the one with no sound or subs)
13. go to streams list add the wav file
14.go to video- filters add-then load subtitler.vdf
(found at)http://www.virtualdub.org/virtualdub_filters
15. it will promt you for an .ssa sub file load the one you created with sub resync
16. put them together--> file save as make sure it is full proccessing mode and for compression change it to the Divx 5.2.1 Codec, so you don't end up with a hugh file.
17. watch your Avi as normal
hope this helps someone
quote]
new%20picture.bmp -
just a wonder, for the avisub's problem : do you have divx codec installed
yup, the latest of all codecs.. haha. divx6.
well, maybe i'll get the above procedure right. i used xvid codec cuz you can control the output file and the quality is just like the same. well, they say its the best coddec in compression... and xvid is what dattebayo uses for their files. -
but you made the font size smaller? choose 14 or 12.Originally Posted by Bonchick
Run your subs through SubtitleWorkshop, get it to auto fix errors then go through them manually and fix the "too long line" errors. Lastly run the subs and avi through avisub, job done!
ive done that. but which one do i use to burn to make a dvd? i tried vts_001_01 nd vts_002_02 but those 2 dont got subtitles on them. only video_ts but when i burn video_ts it shows as a 10 sec. clip. HELP!Originally Posted by Baldrick
Burn the entire video_ts folder, https://www.videohelp.com/author#3;25.
Or burn with convertxtodvd.
How do you add .ass to an .avi?
By showmi in forum SubtitleReplies: 16Last Post: 2nd Sep 2013, 01:22 -
add lyrics to avi file
By frednufc in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2012, 01:33 -
Trying to add intro to AVI
By n00bNeedsHelp in forum EditingReplies: 65Last Post: 24th Oct 2009, 17:23 -
How to add .sub/.idx to avi?
By gOdiSOnyOuRsIDe in forum SubtitleReplies: 2Last Post: 12th Jul 2009, 12:10 -
How to add subtitles to AVI?
By sepehr_s in forum SubtitleReplies: 1Last Post: 16th Apr 2008, 14:10
sa,srt.
