Hello, I would like to use a menu from a DVD Movie in my custom DVD. I use DVD Lab Pro 2, any suggestions? thanks!
What sort of menu is it ?
If it is a still menu, the simplest way is to take snapshots in PowerDVD or MPC or similar, then adjust them in your unfavorites graphics program before importing them into DLP.
If it is a motion menu then you need to isolate the menu and demux it (DVD Decrypter, perhaps), then you may need to alter it in an editing or compositing package, re-encode it, then bring it into DLP.
You will have to rebuild an structures it has yourself.Read my blog here.
You can do it in DVDRemakePro ('replace block' and 'edit button command' options) but only if you don't need changing button writings. I use this method to return original menu for an external track used in my compilation.
One way is to use pgcedit ... it's the fastest method ... no re-encoding or other junk .
1: Load (open) dvd title clip from folder
2: Import menu from other dvd ... you must choose the correct ifo .
3: Edit nav commands / buttons so reaction is as required .
4: Any extra buttons in menu's can simply have "nop" command (no fuction)
5: Save dvd ... play back on pc ... if all works as expected ... burn it .
6: If not all is well ... reopen compilation in pgcedit ... and hunt down the navigational commands that dont seem to be functioning ... resave ... play ... if all is well ... burn ... if problem ... loop to start of 6 .
Take a squizz through the guides section in forum ... if the first 5 pages you will come across some guides of mine ... 3rd or 4th page should still have the one's I used pgcedit in ... you can get some directions from those .
I should be back to those things soon , as there are some gap's left open and not filed in "yet to cover" other area's , mostly related to newbies asking questions as to how it's done , and the pitfall's to avoid that can appear .
Can you rip a dvd without the menu requirement...plz read for nfo.
By darkcyber in forum DVD RippingReplies: 5Last Post: 11th Jul 2011, 22:45 -
How to rip BD with top menu + hd audio?
By dougw03 in forum Blu-ray RippingReplies: 6Last Post: 10th Jun 2011, 13:55 -
How to rip (DVD,HD DVD, Blu Ray) with chapter and menu in 7WMC?
By timf79 in forum Blu-ray RippingReplies: 1Last Post: 19th May 2011, 22:34 -
Rip DVD menu audio
By Silver_Ice in forum AudioReplies: 7Last Post: 27th Mar 2008, 23:33 -
After rip DVD menu not working, any suggestion?
By taylor6698 in forum DVD RippingReplies: 1Last Post: 3rd Oct 2007, 15:10
