    Nov 2006
    It appears that in current NLEs and the Windows Media Encoder that you can do WMV7, 8 and 9 but only flavors of WMA9 for audio. Does anyone have a solution for encoding to the old WMA7 and 8 audio codecs short of building up a Windows 2000 or 98 box? As to why I'm doing this, it's to verify some other tools against the old formats.
    Oct 2005
    Lima, Peru
    Hmmm... actually, since MS made its VirtualPC available for free, you wouldn't need to "build up a Windows 2000 o 98 box".
    Can't you install an old version of WME separately? I think I have a couple of them lying around...
    Nov 2006
    I'm not using a Mac so I wouldn't install Virtual PC.
    The problem is with newer versions of Windows Media Encoder installed the older codecs get deleted or over-written. Again, the video codecs are still available to encode to, but the audio codecs are gone.
    Anybody else have any ideas?
  4. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Actually, there's a PC version, too. I think machf suggested it so that you can have another Windows environment in which to install earlier versions of Windows Media Encoder, without worrying about them overwriting your latest version.
    Oct 2005
    Lima, Peru
    Yep, that's what I meant... installing a different version of Windows within a VM running inside your current Windows installation. If everything else that you've tried fails, you can do that. You can download VirtualPC 2004 here.
    Nov 2006
    Okay, I've tried this. However instead of running Virtual PC, I ran VMware and tried both Windows 2000 and Windows 98 SE. I found a copy of Windows Media Encoder 7.1 and loaded that. This gets me part of the way there.
    With WME 7.1 I can encode WMV8 with WMA 8. There is a video codec for WMV7 but NO AUDIO. This is quite the nightmare. Anybody know where/how I can encode to the old WMA7?
    Thanks loads for the suggestions.
    Oct 2005
    Lima, Peru
    I found a similar discussion here. It's suggested that aside from WME 7.1, you only install WMP 7.1 and its codecs.
