which is fine. I don't want the crap on my computer. (plus second life breaks with QT for some reason but not with QT alternative)
I also don't want .net on my computers either.
my system. does not have to be rational![]()
Results 61 to 62 of 62
To me, they are tools just like all the other ones (you use the best/most appropriate tool for the job). Yes, they are bloated, but they are NOT particularly overly buggy, nor virus-laden. As long as you judiciously install them, they shouldn't become a burden and/or slow-down your system.
For apps that do, that's what VMs, multi-boots, or swappable boots are for. I don't want to be hampered from using the full potential of my tools' possibilities by a particular corporate preference or brand avoidance. But that's MY system. You can do what you want.
Split/Trim/Join MOV files (works great with Canon SX130's files)
By truchopol in forum EditingReplies: 3Last Post: 27th Jul 2012, 11:35 -
Join MOV Video from command line
By parisisal in forum EditingReplies: 4Last Post: 19th Feb 2009, 11:59 -
Join mov files and upload to youtube
By neelapala in forum EditingReplies: 2Last Post: 23rd Dec 2008, 12:09 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 04:37 -
Using Submerge to Join avi Files to srt Files: Problems with Export
By TiggyWink in forum MacReplies: 1Last Post: 26th Jun 2007, 09:16
