Results 1 to 9 of 9
    Apr 2006
    Italy
    Hello everybody, I'd need a combo VCR recorder/DVD player with an S-Video output that could work even for the VCR section. Unfortunately I couldn't find a player with these features anywhere.
    Does anyone know something similar?
    USA
    This is not about media. Moving you to the DVD Player Forum.
  3. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    http://www.kiva.org/about
  4. You can also use adapter between rca and s-video.
    See : http://www.svideo.com/svideorca.html
    Note : This should work for Italy too.
  5. Member edDV's Avatar
    Mar 2004
    That will only work for S-Video to composite not the other way around.
    Composite to S-Video is expensive and lossy. See:
    http://www.amazon.com/JVC-HRXVS44U-DVD-Combo-Silver/dp/tech-data/B0000DD8FT/ref=de_a_s...755618-2280931
    Apr 2006
    Italy
    Hello and thanks to everybody for your replies!
    The solution S-Video cable to RCA is not good for my situation, because it
    The JVC model is interesting, but I forgot to say that I'd also need to reproduce MPEG4 (such as DivX, Xvid etc...) on my player, and unfortunately the JVC models seem to have not this feature.
    So I'd definitively need a player with these features:
    VCR recorder/DVD & MPEG4 player
    VCR through S-Video
    DVD/MPEG4 through S-Video and SCART-RGB
    Do you know something like this?
  7. Member edDV's Avatar
    Mar 2004
    Not I.
    Apr 2006
    Italy
    VCR through S-Video
    Now I'm pretty sure that a similar product doesn't exist...
    Apr 2006
    Italy
    Thanks for the suggestion; however I read that this unit comes with a lot of troubles.... take a look here:
    http://www.amazon.com/gp/product/customer-reviews/B0000DD8FT/ref=cm_cr_dp_pt/102-70543...ustomerReviews
    Do you know if there are any similar, but good working products?
