    Nov 2006
    Mexico
    i'm rendering 5 mpeg-2 files 800MB each one, and i applied this settings:
    FIT TO DISC > OK
    FREE HD SPACE > OK
    No errors displayed, only compression advices. > OK
    The problem is when it starts to render the first Video it stops at 9 % ,and the approximate time left is 0:00
    is not problem with my pc cause i can work perfect,
    i have done this about 3 times and i get the same prob.
    what could be the reason ?
    Mar 2004
    Boise, ID
    Try trouble shooting. First try just one mpeg file and see if that works. Then two, and so on. Check the free space on you HD. You may even need to reinstall DVDArchitect.
    Rob
