    Nov 2006
    Lesotho
    Hi Everyone
    I'm mostly using Avid Liquid for editing, then export mpeg2 file for authoring in Encore DVD 2. Mostly, my dvd do not play well on a TV DVD player. They will play well say for the first 10 minutes, and eventully keep jamming as if DVD is scratcged, and subsequently the DVD will jump back to the menu. This jamming behaviour does not happen exactly at one point, sometimes it will happen at 10 min, when I play the same DVD again, it might be at 11 min. I'm getting the same problem even if I try Authoring from within Liquid. I'm using Verbatim DVD+R blanks
  2. It sounds like your DVD player doesn't like the media or it has alot of errors.
    1.Does the disc play fine in your PC?
    2.Use Nero CD-DVDSpeed (Disc Quality) to check the disc for errors,it should have <200 max PIE and <20 max PIF.
    3.Try another brand or batch of DVD+R,Verbatim are usually good but you might of got a bad batch.
    4.Try DVD-R.
    5.Update your firmware: www.rpc1.org
