Here's my new problem.
I have 2 cd's... 700mb of DivX .AVI movie each.
I want to make it one movie and burn it on one DVD.
Since I usually encode a 700mb .AVIS to 4.3gb .MPV, what if I encode a 1.4gb .AVI to a 4.3gb .MPV? Will that reduce the quality dramatically?
What is the proper way for doing that?
Thanks.
Enter the total runtime of the two AVI's into the bitrate calc on this website www.videohelp.com/calc take the bitrate that it gives you then convert a small clip to MPEG using your preferred encoder. Does it look ok to you?
He's a liar and a murderer, and I say that with all due respect. -
Size doesn't matter. A 120 minute movie compressed to 700mb and blown up to DVD will generally look a lot worse than the same 120 minute movie compressed to 1.4 GB then blown back up for DVD.
Running time is what matters. What you don't understand is that the 700mb source is much lower to begin with than a 1.4GB source.
As pointed out, encode the two halves using the bitrate derived from the total running time. Don't try to join them first. Load the two parts into TDA onto the same track, then remove the additional chapter point that TDA adds at the start of the second half. Put in any additional chapter points you may need, compile, and you should get seamless playback.Read my blog here.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
