After upgrading to version X from version U, ffmpegX insisted on reinstalling the binaries every time I started the app. I posted for help and no one answered. Major's readme says you don't need to upgrade your binaries, but I had bookmarked SourceForges' download page, so I went back to look again.
http://sourceforge.net/project/showfiles.php?group_id=62947&package_id=70503&release_id=162732
is the link.
There is a later version of the binaries for mplayer and mencoder than I had, and they were accepted, BUT, I have a ppc G4, and ffmpegX keeps asking for the Intel version of mpeg2enc even though it obviously won't work.
The workaround is to do 2 binary installs for mpeg2enc, one for the ppc version so that part works and then install the Intel version just so the app will leave you alone.
And don't forget to get the Real library components from the same SourceForge page to copy manually to the Library>ApplicationSupport>ffmegX folder if you want those to work.
Ack, I suddenly got this problem as well!!!
ffmpegX kept asking for the last two binaries every time I re-launched the app.
Then I remembered the most recent change I performed on my system was running a free utility called Monolingual - it removes languages and Intel/PowerPC components that your system configuration doesn't need - it must have removed some code fragments from ffmpegX as well.
I launched ffmpegX from an old backup and installed the binaries again and relaunched the app.
And that seems to have fixed it!
Bizarre Premiere Pro bug that I can't find a workaround for
By Asterra in forum Newbie / General discussionsReplies: 8Last Post: 28th Jun 2011, 20:46 -
mkvmerge on ppc
By kirti in forum MacReplies: 2Last Post: 7th Jan 2009, 09:17 -
Can't install mpeg2enc binary
By cpwhaley in forum ffmpegX general discussionReplies: 3Last Post: 23rd Jul 2008, 13:50 -
yuvscaler PPC ?
By ResEdit in forum ffmpegX general discussionReplies: 5Last Post: 28th Jan 2008, 13:10 -
Possible display bug - minor, with workaround
By Neil Herber in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 12th Sep 2007, 18:00
