I'm having problems with Xvid seemingly uninstalling itself (atleast it acts that way) however the files are there. The avi's still playback but it gives me codec errors upon opening them in WMP(Windows Media Player) also if i try convertering them into a different format the audio and video is out of sync. Yes the audio is VBR MP3 however the more pressing issue here is why it keeps removing itself as a codec. here's the specs on the software versions
Xvid - Kopei 1.1.2 (Nov 2 2006)
WMP - Ver 11
WinXP - SP2
Thanks in advance for any assistance you may provide.
I would suspect WMP as the problem. It has a few.
Try a different player. Media Player Classic if you like WMP, or VLC, which doesn't need an installed codec for Xvid.
MP3 VBR will usually cause problems with conversions to MPEG-2 with most MPEG encoders. You didn't say what format you were trying to convert them to.
Other than that, what specific codec errors are you getting from WMP? -
Give VLC a try. It's often a good test to see if you have a corrupted codec. The Xvid codec can get corrupted, the same as most any other codec. I hope you haven't installed any codec packs lately.
That's a fairly common cause of messed up codecs. If no, try deleting and reinstalling the Xvid codec.
MPC is usually a good player, if it has the proper codecs installed.
If you need to use MP3 VBR audio with MPEG-2, you can extract it with VirtualDub or VD Mod as a WAV file, then use that with your encoder to often avoid sync problems. This guide from jimmalenko may help: http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm
Codec Conflicting Issues
By ohnoeee in forum Newbie / General discussionsReplies: 18Last Post: 7th Apr 2011, 12:47 -
serious codec issues mac?
By aceswild in forum MacReplies: 10Last Post: 20th Nov 2009, 14:45 -
Vid Codec issues..
By Horseysi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 8th May 2009, 11:44 -
Intermediate codec and xvid question, and xvid to wmv.
By ^xRun^ in forum Video ConversionReplies: 9Last Post: 22nd Jul 2008, 18:13 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
