    Jan 2006
    Hi Guys,
    I just have a quick question;
    I capture xbox games with an ATI TV Tuner Pro PCI and MMC 9.08. I have it set to "Ask at end of recording". So I hit record, then I hit stop recording when done. Then it asks if and where I want to save(Although it is set up to record to a certain drive). If I accidentally press Cancel instead of Save,...is there a way of digging up that file? Does it save to a temp file or something?
    I don't know if it makes a difference, but I use HuffyUV at Fastest/Fastest 640X480.
    Thanks alot.
    It might be in a hidden ATI folder on one of the hard drives. Then again, it's probably gone.
  3. Banned
    New York, US
    Why not turn off "Ask at end of recording"? That way, it will always keep your capture file and you'll always know where it is. If you don't want it, delete it later.
    Jan 2006
    Yes, I think I'm going to stick with this. I did it the other way, because space is limitted. I am capturing to AVI 640X480 with HuffyUV, so file sizes are quite big.
    Thanks guys.
