I was wondering if anyone could help.
I have a Standard Definition Panasonic 'Viera' Plasma Television.
Is there anything to gained from connecting a High Definition Set Top Box as opposed to a Standard Definition Set Top Box.
Any thoughts or advice would be appreciated.
	it would look slightly better - but not by much as EDTV 's are pretty low res. to start with .......
 the panasonic plasma's are an awesome good pic though - specially the new 9th generation panels (i have one (the HD model) that just came out) -- equal to my pioneer elite i would say in many respects ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
  Motorola DCH3416 STB capturingBy NitroVideo in forum Capturing and VCRReplies: 4Last Post: 11th Jan 2014, 16:32
  any known SKY+HD STB problems.??By snadge in forum DVB / IPTVReplies: 4Last Post: 22nd Mar 2009, 17:05
  Capturing from STB with firewire.By Red Hat in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 05:50
  Do I or will I need STB for digital video?By larrym in forum Capturing and VCRReplies: 10Last Post: 4th Aug 2008, 00:51
  Help finding ATSC STBBy TomTee in forum DVB / IPTVReplies: 30Last Post: 16th Sep 2007, 19:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
