in the past on my G4dual I had an alchemyDVR card and recorded analog TV with sorensen3 to 320x240 files.
I edited them and then saved them as 3ivx files that ended up about 150MB for 20 minutes of TV
this worked for me as I used QTPro to get rid of what I didn't want and then Batch Export Utility to do the final 3ivx conversion in a batch, unassited.
now with my MiniHD I get initial file sizes of about 900mb for 680 TV and 3gb for 1080 HDTV for 28 min.
using SClip I can batch a lot of them over night but need help in selecting the initial codec of choice for a final 150mb 329 x 240 file size.
I can edit with QTPro after the streamclip to QT, then use BEU to go to the 3ivx.
im just unfamiliar with all the Streamclip to QT codec choices
thanks
Results 1 to 1 of 1
MPro 2.66 3GB RAM 1.5TB HD's
MigliaMiniHD
QTPro, MPEG2 add on MPlayerX2
MPEG Streamclip
24 + 21" samsung flat panels
G4dual 2GB
AlchemyDVR card
VirtualDub missing compression codec options?
By raena in forum Newbie / General discussionsReplies: 15Last Post: 9th Sep 2015, 19:47 -
mpeg streamclip
By devdev in forum Video ConversionReplies: 2Last Post: 25th Sep 2010, 05:49 -
Can't Get Started with Streamclip
By cindyjk in forum MacReplies: 20Last Post: 22nd Feb 2010, 15:41 -
MPEG Streamclip help!
By squid3660 in forum Video ConversionReplies: 0Last Post: 5th Jul 2008, 22:56 -
By kita in forum MacReplies: 18Last Post: 28th May 2008, 02:14
