Running Windows 98SE with Internet Explorer 6 when trying to go to Yahoo mail, Hotmail or any web based email it gives error message, "Microsoft Internet Explorer has encountered a problem and needs to close. We are sorry for the inconveniencd." It then gives option to send error report and restarts Internet Explorer, but there's no problem accessing other web sites. I tried repair Internet Explorer option in Add/Remove Programs, but problem persists. Has anybody else had this problem or know a fix?
Results 1 to 12 of 12
These sites rely heavily on AJAX and XML - maybe your (now) old OS doesn't have support for that?
/Mats -
No such problem exists with Mozilla or Netscape which indicates problem resides with IE6.
What version of Java do you have installed? Also, are you sure you don't have any BHOs or spyware installed that might be causing problems?
If cameras add ten pounds, why would people want to eat them? -
Java version 5.0 which is latest according to Java site. I'm running Avast anti-virus as well as Ewido anti-malware and have no malware I'm of which I'm aware.
Do you have any BHOs (not necessarily malware) that you think might cause problems? Or running processes?
What happens if you clear your cache and cookies (back up your cookies first if you prefer), then try the sites again?If cameras add ten pounds, why would people want to eat them? -
Browser Helper Objects
/Mats -
Yeah, I had a feeling I should've written it out instead of using the acronym. It's why I shouldn't make forum posts in the middle of the night.
Grab hijackthis ... bho's will show straight up in the list ... with this tool you can remove them ... however should you revisit a site that requires these they get recalled , and there back once more .
You can also disable stupid programs that run from the startup ... like stupid quicktime , printer utility , and others ... it makes the pc load faster so you can get going .
If you see anything strange in the list , go to the hijackthis forum and do a quick search for the item and see if anything turns up ... it may be nothing ... then again ... it could be a problem .
If it dosent show there ... then do a google search should nail it down .
Drsmartdownloader , kyb??? , kyb??? , kyb??? ... if there is more than four of those , you are infected with right pains .
Mozilla browser would be a better choice on aging os ... atleast if ie keeps packing it in , you have a backup ... and one that has a download manager thrown in for free . -
Google search finally found resolution at http://www.windowsbbs.com/showthread.php?t=53494 in case it may help others with same problem.
Odd that a problem with msvcrt.dll would only show up on those sites, though. (But I'll have to admit I know almost nothing about the DLL, anyway.
Glad to hear you solved the problem.
Internet Explorer 7 tabs problem
By Nintendo Fan in forum ComputerReplies: 4Last Post: 25th Feb 2010, 18:41 -
Internet Explorer 8 Keep Crashing
By Squid_uk in forum Newbie / General discussionsReplies: 6Last Post: 27th Oct 2009, 17:44 -
Internet Explorer 6 problem on Windows 2000
By edong in forum ComputerReplies: 17Last Post: 23rd May 2008, 00:04 -
something wrong with internet explorer
By ssaamm in forum Newbie / General discussionsReplies: 9Last Post: 5th Oct 2007, 07:28 -
How can you get rid of Internet Explorer?
By video_enthusiast07 in forum ComputerReplies: 8Last Post: 10th Jun 2007, 18:05
